DIY air leveling bags
hedge
https://www.youtube.com/watch?v=x19Wsx2OSz8
Found the original thread by Mike_mn
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/21143513.cfm
I came across these in the TT forum, how do you think they'd work with a TC? I like the idea of the adjustability and how they collapse to nothing, not sure how much the weight capacity of these would be.
I think I'm going to try build some over the long winter, just have to try find the discharge hose.
2017 F350 Platinum DRW
2013 Adventurer 89RB
18 REPLIES 18
ralphnjoann
OOPS!
covered_wagon
Cedar 2x6 blocks are light weight but do split easy if you don't criss cross the grain with one on top of the other. However, if you ever get a flat you'll appreciate having a couple blocks to set the tire jack on top of. Wood blocks also help level the Honda generator and back scissor steps. I also like the blocks for weighting down the picinic table cloth from blowing off.
Easy and inexpensive to replace any damaged blocks.
CaveRun
Much ''faster'' and ''easier'' to just use ''leveling blocks'' or ''wood blocks''!..IMO!
John 3:16
1996 Hide Away Sun Lite Truck Camper
2003 31' Salem LE Forest River Travel Trailer
2013 Sun Tracker Bass Buggy 18 DLX Pontoon
2002 F-150 SuperCab V-8 4X4
Firestone Air Bags
Homemade Tie Down Mounts
Equal-i-zer WD Hitch
covered_wagon
It is not healthy to have everything in life too easy. Up to a point anyways, you'll live longer with a bit of hard work in your life. I'll stay with blocks.
hedge
It's great to hear from someone that has them. Pretty much the advantages I would have thought. I think they'd work quite well for us.
I still think I want to try build a set, I can find the material online but the shipping is killing me so I'm trying to find the materials locally.
ralphnjoann
skipro3 wrote:
ralphnjoann, knowing now what they do and what they would cost to build from scratch, would you say it's worth it or other options are as good or better?
IMHO it's worth it for several reasons. They take up less space and can be folded in half for more storage options; you're dealing with only one item per wheel as opposed to several; and, you don't need to estimate how high the wheel needs to be raised since inflation will take care of that.
I use a small hand-held battery operated air pump to inflate them. It takes a few minutes so I let it run while I do other outdoor stuff whilst periodically checking the bubble level.
Ski_Pro_3
ralphnjoann
I built a pair of these when the instructions first came out and I followed the instructions to the letter. At the time, I had a dual axle fifth wheel with a GVWR of 7800lbs. I now use them with my truck camper which weighs 2300 lbs, on an F250 SRW (I know, I'm overweight), but back to the air bags. I've never had a problem. They do what I need them to do, and have done so for years. I can tell you this; you won't build two of them for $100 if you have to buy all your materials at today's prices. It will be considerably more. BTW, I don't like to lay them directly on the ground because of potential puncture problems. Trimmed down 18 wheeler mudflaps under the bags eliminate this worry.
jimh406
BeatCJ, thanks for the explanation. I'm not understanding why these are helpful or easier for a TC, but I guess I don't have to. 🙂
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
BeatCJ
jimh425 wrote:
It is interesting, but you can buy the airbags without all of the mounts. It seems like starting there would save at least part of the full cost of a set, but be a lot less work even though you would still build brackets.
Different type of bags. These are intended under the tires of a TT, to level before you engage the jacks, instead of stacking blocks. Our individual wheel loads on a truck camper are higher, so I'm not sure how well they would work.
As for the amount of lift, at 30 psi you would get 3000 pounds each bag. With dual wheels, that would give you 6000 lbs per side. I wouldn't be surprised if it would work to 50 psi, that would give you 10000 lbs per side. Typically, hose is proof tested to 4 times the rated pressure, so there is a safety factor there. Obviously, considerations for safety would need to be made. I doubt the stem would shoot out, if you used the backup washers as shown in the instruction post. If you really need that much lift, even consider a second layer of hose for reinforcement. But it would probably be prudent to make sure they were positioned toward a solid object.
Gordon
Now
2001 GMC 3500 DRW, Duramax
2021 Outdoors RV 250RDS
Old
1987 F-350 XLT Lariat SRW 6.9
1986 Western Wilderness Alpine Dinette 11
jimh406
Ski_Pro_3
hedge wrote:
They only go to 30 psi, I don't think that's a big concern.
30psi gives 3000 pounds of lift. Each of my rear tires are more than that. I have 3600 pounds on each tire. (7200lbs on the rear axlse) So that means, at 30psi, the bags still haven't lifted the rear tire.
AnEv942
Don't think your going to stack them if needed. Looks like might be fun to make but for the cost & effort not seeing as very practical. Coarse I guess you could add on top of block?
Be fun in some slick mud, Truck camper hockey!
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page
http://www.ourelkhorn.itgo.com
hedge
