- ScottGNomadNo and if you install one your dealer may use it as an excuse to deny warranty coverage if the trans has any kind of issue.
- ib516Explorer III have digitally monitored the temperature of the ATF in my last 3 vehicles, all with just factory trans coolers. None ever got too hot when towing.
So my answer is no, it's not needed. - JaxomExplorerA cool transmission is a happy transmission. If you have the factory tow package you should be fine. It won't hurt anything to add a transmission cooler. Doing so will also help keep your engine coolant cooler, assuming the transmission fluid shares the radiator with engine coolant.
- TNRIVERSIDEExplorer
ROBERTSUNRUS wrote:
:) Hi, the factory coolers are rated to handle the tow ratings of the vehicle; So nothing else is needed. If you tow beyond the factory ratings, well, you shouldn't. So no.
Good answer. X2 - ROBERTSUNRUSExplorer:) Hi, the factory coolers are rated to handle the tow ratings of the vehicle; So nothing else is needed. If you tow beyond the factory ratings, well, you shouldn't. So no.
- mdamerellExplorerIf the truck has a tow package there will often be upgraded coolers installed. If you have an oil and transmission temperature gage it should answer any concerns.
- Turtle_n_PeepsExplorerNo
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
