work2much's avatar
work2much
Evaporative Cooler
Does anyone use one?
We are removing our roof AC due to the fact we never use it. In fact we have never used it once. Sure there were times that we were hot but using the air means running the genset which we also never do. Too noisy, uses up propane etc.
Recently my father passed and while settling his estate we used his evap cooler and found it to be superior to AC in that it was a nice moist cool which countered the dry heat in Reno.
We are considering replacing the roof AC with fantastic fan or...
This
Anyone use one?
Initial pros and cons that come to mind:
Pro:
Light and simple.
Very energy efficient does not need a generator
Adds moisture to dry air
Cons:
Requires arid conditions. Works poorly/not at all in humid climate.
Pretty expensive for what it is
Requires pumping water into reservoir on the roof (what could go wrong?) :S
Anyone with experience with one of these?
Thanks, Greg
