Does anyone here use air shocks?
Groover
It seems that I have seen a lot of discussion on here about air bags vs Timbrens or Supersprings but I came across these air shocks that seems to be reasonable priced and easy to install. They are not as strong as the other devices but are probably all that I would need on a half ton truck. So has anyone tried them?
http://www.autoanything.com/suspension-systems/61A5839A0A0.aspx
14 REPLIES 14
mowermech
About thirty or forty years ago, I had air shocks on one of my vehicles.
Within the parameters detailed in the instructions, they were great. They are not intended to replace overload springs!
As always, when all else fails, read and follow the instructions.
CM1, USN (RET)
2017 Jayco TT
Grit_dog
Navigator
Navigator
I put some on my 70 impala back in high school so I could get the jacked up rake look when I wanted it. Wouldn’t use them on a truck for hauling anything heavy.
rhagfo
Groover wrote:
The reason that I asked is that a family member has found a gooseneck horse trailer that is light enough to be pulled with an F150 but the gooseneck hitch is not compatible with air bags from what I have been able to find out. So my choices are no extra support, air shocks, Timbrens or Super Springs. Etrailer.com recommends Timbrens for use with the hitch. I like the adjustability of the air springs and am concerned that the use of one of the other type devices will make the empty ride too harsh.
Have they installed the hitch yet? I would get the hitch installed and load the GN and hook it up and see how it sets, could be surprised.
I am a firm believer that a GN or 5er is a far safer and more stable package even at max GVWR than a bumper pull.
Bedlam
Moderator
Moderator
Firestone makes two different mounts based on whether you have a goose neck or fifth wheel hitch installed.
Groover
Well, it turns out that etrailer's advice that air bags don't work with a gooseneck hitch apparently does not apply to the Airlift 5000 bags with built in jounce bumpers so we are keeping the Airlifts for now. Putting in the gooseneck hitch was easier than I thought that it would be and the F150 seems to pull it well. We did use a 5" offset ball to give us a more clearance from the back window with the 5.5' bed. We looked at going with an offset coupler on the trailer but decided that the benefit would be minimal as that type of offset does not help much when the trailer is sideways.
Passin_Thru
Firestone makes airshocks for 3/4 ton front ends and I'd go with the Airlift bags on the rear. Have run them for years. I run about 15-20 lb ety and it takes the shock out of a 3/4 ton ride.
drsteve
I had them on a 3/4 ton conversion van that I towed a 6500 lb loaded TT with, and they didn't do the job. As other have said, shock mounts are not designed to carry weight.
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
TurnThePage
I would add a leaf long before I would trust an air shock with a heavy load.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
LIKE2BUILD
I have Timbrens on my Ram 2500. I set up mine to set about 3/4" above the spring perch so under normal driving conditions they don't make contact. When I drop my 5th wheel in the bed the truck squats to make contact and they provide excellent helper support for my coil springs.
KJ
'14 Ram 2500|Crew Cab Long Bed|4X4|Cummins
Curt Q20 with Ram 5th Wheel Prep
2000 Crownline 205BR
1997 Ranger Comanche 461VS
'01 Polaris Virage TX PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (21, 15, & 13)
1 forgiving wife!!!
Groover
mkirsch
Nomad II
Nomad II
That's my understanding as well... Shock mounts are not designed to be load-bearing, so if you go into this thinking air shocks == air bags, you will be sorely disappointed.
Don't think that they'd be all you need because, "it's only a half ton truck." Half ton trucks are the ones that need the MOST help usually.
carringb
Except for the Bilsteins made for the GM SUVs, most air shocks are lacking in the damping department. The Bilsteins are huge however, so they don't fit other applications. The more modestly sized air shocks make it all fit by reducing both chamber sizes, so they don't do either function very well.
2014 ORV really big trailer
2015 Ford Focus ST
JIMNLIN
Shock mounts aren't meant to carry weight. Now if the full size car or burb or suv needed help with leveling light loads then they may work in that situation.
theoldwizard1
Helper air spring are more durable.
