transamz9
Sep 24, 2013Explorer
tsetsaf wrote:4x4ord wrote:
If you are buying the truck for a fiver make sure it has enough payload to handle your pin weight. I wouldn't bother with a 3/4 ton, go to a one ton SRW unless you're planning on getting a huge 5'ver (over 3000 lbs pin weight) in which case a dually might be better. My personal preference is a short box SRW without a sliding hitch.
I agree with the above except for slider hitch. You will need the ability to 90 degree the trailer at some point in time; why worry about it. We found our superglide new used for 400 on craigslist.
At some point you are going to have to learn to back your trailer. You should never have to get 90* with these trailers. If you want to tear up your stuff then do it but don't say you have to get 90* because it simply just ain't true.:S
