Atlee
May 30, 2019Explorer II
Could it be simply a matter of more air in the tires?
Last Thursday, I replaced the OEM BF Goodrich Rugged Trail LT245/75R17 LRE tires with the identical sized BF Goodrich All Terrain KO2 tire.
Up until last Thursday, my truck with the OEM tires (always inflated to 55# front/60# rear per the yellow sticker on the door jam) and the Jay Flight 23RB trailer were an extremely stable combo. 99.9% of all passing 18 wheelers never wiggled the combo. Normal winds had little effect.
However, the first tow with the new tires and same trailer, loaded about the same, was closer to a white knuckle affair. The air pressure in the new tires was the same as the OEM tires, 55# front/60# rear.
Would it help if the new tires were aired up more? Say to 65 or 70 in the rears, and 5 to 10 pounds more in the front?
The basic tread design is exactly the same between the two tires. However, the new tires are 3 pounds heavier per tire, has a slightly deeper tread, and counting the heavier, larger shoulder lugs, is about .5 inches wider.
Any thoughts?
Any thoughts?
