โMar-17-2015 12:36 PM
โMar-27-2015 07:36 PM
colliehauler wrote:Major Dad wrote:If you take out the back seat you may be able to build a platform out of plywood. On my Ford crew the platform was 58"wide by 45"deep and has enough room for 3 Collies. Your megacab would be even larger. You could measure and cut cardboard the same size and lay it on the ground and have your 2 dogs lay on it to see if it would give you enough room. If not you won't have to change your truck.Highway 4x4 wrote:
I found that heat was a big problem back there for the pups. It's hard to get AC back there when it's hot. I would have a remote temp gauge back there. If your dogs get stressed and hot, you've got a big problem. The noise level is also high. I have a Bed-rug in mine. You should have gotten a Megga-cab.
I have the megacab and two large dogs. ONE St Bernard may fit back there with the seats folded down, but not two. I'm thinking for giant dogs maybe a 3/4-1 ton van may be the answer, with rear seats removed. The cap on the pickup truck would be a factor in hot weather since the OP lives in West Texas.
I thought of a 1 ton d-max van but it was De-rated on power with a lighter duty transmission. This would limit you to a TT as well.
I wrapped the back seat in plastic and store it in the garage. Would take about 15 minutes to put back in.
โMar-27-2015 11:47 AM
dvitale300 wrote:
Yea - having the same thoughts. My problem is that I have a shell on my truck, but the hatch won't go all the way down when hooked to the trailer (hit's the propane units). Un-hitching the thing every couple hundred miles so they can pee is not an appealing idea.
โMar-27-2015 11:04 AM
โMar-27-2015 10:42 AM
โMar-27-2015 07:57 AM
โMar-27-2015 04:45 AM
Highway 4x4 wrote:This is what I found as well that heat was a problem. After one summer trip I sold a Dodge 1 ton with only 2500 miles and bought a Ford crew cab. This was before Dodge had a mega cab. The Collies ride in the truck..
โMar-26-2015 09:23 PM
โMar-26-2015 09:08 PM
โMar-26-2015 11:22 AM
Highway 4x4 wrote:
Congrats Dvitale300,
Showing a Saint is not easy. I have a show Bernese and he travels with me in the cab of my new Ram Laramie, fold flat floor in the rear. I would not travel with him in the TT because I need someone to talk to on the long drives. Not being able to lower the tailgate is also a bummer. Is there room to move the tanks back and then move the tongue jack back enough to clear the tailgate? Might need to do some welding to make it work. Think outside the box. How close is it to clearing? To help with the dog hair some I cover the entire back seat area with a sheet and take a few along on longer trips. Use the dog blower to blow out the truck. If you have too much dog for the cab you'll just have to get a class A MH like all the big dogs at the shows. Do you have your X-pens mounted on the back bumper yet?
โMar-26-2015 10:28 AM
โMar-25-2015 10:17 PM
โMar-25-2015 04:08 PM
โMar-25-2015 02:22 PM
โMar-25-2015 01:03 PM
downtheroad wrote:
I couldn't care less about what others' take is on this topic. Our girls ride with us. They are part of the family.
โMar-25-2015 07:06 AM
