philh wrote:
Newb...
i drained the pink******out filled the tank, ran it through both hot and cold and then drained it again.
Filled the tank again with water and 1/4 cup of bleach. Ran that through the system and drained it again
Filled the tank again and drained it.
Since I really don't want to carry extra wt, traveled empty and filled at the campground. I don't know WTH was in the water, but it was AWFUL. Ran to the store the next morning to buy a jug of water.
One flaw in my fill and drain procedure, trailer was not level in the driveway and likely trapped some water. When I took it back to storage yesterday, I pulled the plugs and opened the faucets letting it completely drain from the low point. Just dawned on me that i failed to pull the hot water tank plug.
Anything else I should or can do? How good are the single stage under counter filters?
First, you should use about 1/4 cup of bleach for every 15 gal of water.
Second, contact time, you need about 4 hours of contact time.
Then drain, no need to repeat. A simple flush of the lines and you should be good to go.
