- Bigfoot_affairNomad IINever ever had a problem with any window motor or switch on my GM's. For me and others I know it has been a broken wire inside the rubber boot between the door and the body, wires travel from the body to the door and after opening and closing the door a million times the wires work harden and break.
With the key on try holding the window switch in the direction you want it to go and open/close the door, sometimes if the wire is holding on by a strand you might get some movement out of the window for a split second, its worth a try. - Turtle_n_PeepsExplorerGood money is going to be on the motor and not the switch. Could be the switch but not likely.
- Peg_LegExplorerI think those switch pods have a plastic arm with a barbed catch on each end. One end may have two of the clips, CRS. I usually lift one end with a putty knife while trying to keep it tilted downward toward the bottom of the arm and applying pressure to push the clips barb so it will clear the hole. Slipping something like a pencil under the putty knife for a fulcrum helps.
- robsouthExplorer III have done it several times and can tell you it is not as simple as the videos make it seem. Most things inside the door are attached with rivets so plan on drilling them out. Working space is very tight and at times you wish you had a little kid to reach in some the the places that you might need to access. As mentioned, check voltages at the switch and motor etc, before you begin removing anything. Generally, there are not separate fuses for each window, just one for all. It is doable, but pretty involved, especially your first time.
- ramyankeeExplorerAnother question I should have asked.....Would there be a separate fuse for each window switch????? Because NO, I did not check the fuse because three windows work.
- mlts22ExplorerI know people who swear by De-Ox-It, which not just works as contact cleaner, but prevents future corrosion from happening.
- Perrysburg_DodgExplorerFrom the video I watched it looks like a very easy job. Gently pry off the window switch pod, using a plastic trim tool (if you don't want to damage it).
Then check the switch using a volt/ohm meter to check the power coming to the switch (with key on). If power is found then check the switch and window motor using the ohm function and replace the bad part.
If no power is found then you will need to take it to a shop to find out what is wrong. The fact that you asked this question means you should stop at this point.
BTW I'm assuming you have already checked the fuse right :W .
Good luck Don - Campfire_TimeExplorerIt could be the switch, but my experience with GM windows is that it is more likely either corroded contacts or a bad motor. Before getting a motor, you'll have to follow most of the instructions in the video and clean all the contacts you can find. I think Radio Shack still has contact cleaner. There are some good videos online about cleaning these types of contacts. If you do end up replacing the motor its fairly easy but be careful not to break the white plastic retainers that hold part of the door panel on. Also be prepared to get cuts while getting the new motor in place. There's not a lot of room to work inside doors.
About Travel Trailer Group
44,028 PostsLatest Activity: Mar 15, 2025
