Tiggs wrote:
The space between the TT tires will accommodate one leveling block but if the side to side difference is more extreme I can't place two side by side with a third on top to build a ramp to level both wheels. Trying to roll up on two stacked on top of each other just pushes the block forward.
Don't try to build your "ramp" between the tires. Leave yourself enough room to pull up (or back up) about 5 feet, then build your ramp either in front of or behind both tires. Then pull up (or back up) four feet to put both wheels on your ramp.
