Moving up to a dually and don't really have any experience with them so I have a couple questions. 1. I level by driving onto blocking, for the rear tires do I need to put blocks under both duals o...
I don't like the way the tire bends with only one block, so I use two. I tried it.
There are a lot of different ways to add air including a different chuck or air gauge. They can also be misaligned. I'd get the dealer to give you a walk through on how to do it for your truck. I run the same pressure. I've never heard of the crown thing but with that logic, you should run different pressure in your outside and inside tires in the front as well.
