Dump Valve Leaking
boosTT
When back flushing the holding tanks, I forgot to open the T-handle to actually fill the black tank. A lot of water pressure built up in the little 6" section of pipe after the T-handle.
Now I have a small drip coming from the dump valve even when the t-handles are closed and cap is on. It appears to be coming from where you connect the hose (just as if I left the T-handle cracked open).
Is there a easy way to fix this? I was thinking maybe greasing the valve could help a bit?
10 REPLIES 10
lostbytes
There's videos on YouTube on changing dump valves...
Farmboy666
Should be 4 bolts, one on each corner. Maybe 3/8 or 7/16 wrench. Pretty straight forward. Don't over tighten it will make valve hard to open/close.
boosTT
Does the old valve just unbolt?
NMDriver2
Some end caps only have two bayonet grabbers and some have 4 if yours only has 2 go buy a 4 point cap. Even if you replace the valve the 4 point cap will keep things closed better.
Turret Class traveler
lostbytes
I usually put a cap with a good seal on it till I get around to replacing the valve. I have at one point put bearing grease into slide groove after dumping one time and it did help but only temp solution at most.
Dick_B
Bristol is the 2nd one but Valterra is #1.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
ksg5000
Farmboy666 wrote:
Forget rebuilding, thay are less than $15 each. Just replace
x2
Kevin
Farmboy666
Ron3rd
Buy a rebuild kit and rebuild it. Two major valve mfgs; Valterra and (can't remember the other one). The two are not interchangeable.
Equilizer Hitch
Honda EU2000
Lynnmor
Pull it apart and inspect for cracks, then replace the seals or the entire valve as needed.
