- APTExplorerBuy a cooler and a lot of ice.
- boosTTExplorerGet a propane fridge or propane cooler-style fridge. Or just use ice.
- JiminDenverExplorer IIIs this trip to a dry campground unique? For a one trip deal I would suggest you get a cooler and some blocks of ice and use that for a week. There are members here that do run 120v fidges but they have spent a lot of money making it so they can.
Of your options
A small inverter generator is the easiest except that you can not run one 24/7 in most campgrounds. They usually allow a few hours in the morning and again in the evening. That's a lot of time the fridge will have to hold it's own without running including over night.
To keep it running in between you will need a larger battery bank and a inverter to provide 120v .
Those batteries wont last a week so you are back to having a generator to charge them or at least a simple solar set up.
This is why I suggest a cooler with ice blocks if it is a unique trip for you.
Smaller inverter generator $500-900.
Battery bank and inverter maybe $600
Simple solar system $400 or so
Since we only camp without hook ups we have spent the money to be able to do so, I would not have done so for the occasional trip.
If your fridge is a smaller dorm style, you might want to talk to westend. He runs a small dorm fridge off of batteries and solar. - Nvr2loudExplorer II
DiskDoctr wrote:
120V only? Full size or dorm size?
Either way, here is a suggestion that can reduce your electrical need and increase the stability of your fridge temp.
ICE. Remember your fridge is essentially a power assisted icebox/cooler. Adding ice to the freezer compartment can significantly reduce your cooling needs.
And to add to that thought... thermal mass.
Bring a cooler full of ice with pop / frozen water bottles / frozen juice boxes. Whenever you have any left-over space inside the fridge, fill it with items from the cooler. It takes a lot of energy to keep the air inside a fridge cold, but cold beverage containers need very little to keep them cold. (Don't put warm pop or water in!!!) - DiskDoctrExplorer120V only? Full size or dorm size?
ICE. Remember your fridge is essentially a power assisted icebox/cooler. Adding ice to the freezer compartment can significantly reduce your cooling needs. - pianotunaNomad IIIHi,
You could look at getting a decent sized solar system. It costs a little more--but you never buy fuel again. - ScottGNomad
gunner65 wrote:
You do not have a gas capable fridge? Usually a popup will have a 3-way fridge 12V, 110V, and propane
The OP stipulated in his post that it was a 120V fridge. - bywaysExplorer
ScottG wrote:
You need a quiet generator. Something like a Honda, Yamaha or even Champion, 1000 to 2000 watt inverter generator.
x2 - gunner65ExplorerYou do not have a gas capable fridge? Usually a popup will have a 3-way fridge 12V, 110V, and propane
- ScottGNomadYou need a quiet generator. Something like a Honda, Yamaha or even Champion, 1000 to 2000 watt inverter generator.
About Travel Trailer Group
44,056 PostsLatest Activity: Jan 12, 2020
