New to Rv-ing and loving it. It will be a month or so between our trips so would you recommend draining the hot water tank between trips? I do not keep it heated while the camper is at home.
I only put my own water in my clipper (always fill the fresh tank at home, don't hook up to RV park water). I don't drain mine. My kitchen faucet is a single handle, so I flip it in both directions when I'm home and the water heater isn't lit - I get cold water both ways, but it will pull from the hot water tank so the water doesn't stagnate.
