cumak
Jun 06, 2016Explorer
Eternabond and skylight screws
Hello,
I just installed a new skylight and roof vent on my TT, and I used Eternabond tape to seal around the flanges. I also used Eternabond primer so the tape adheres very well, but I'm concerned about the screw heads. At each screw head there is a quarter-size air bubble because the screw prevents the Eternabond from laying flat on the flange. See photo below.
I'm wondering if this is something I should be concerned about, or if this is normal.
One thought I had was to make a small cut in the Eternabond around the screw heads so that the tape will lay flat. The screw heads would be exposed, and I could seal them with a little bit of Dicor.
I'd appreciate any thoughts or comments. Trying to get the roof repairs finished for our first trip of the season in 2 weeks.
Thank you.
Thank you.
