covered_wagon
Jan 10, 2021Explorer
Everyone Check your Female 7 pin connector.....
I cracked my 7 pin female connector on my camper. I went to replace it today and found the wires not striped enough and had wire insulation pinched in all the screw clamps. Bad work, but then found the ground in the center was never striped at all. They just tightened the screw a bunch expecting it to pinch thru the insulation. I found only one thin tiny little wire braid had been touching the terminal. That's bad workmanship! So check yours out, problem is you have to take it off the camper body to get to it and take it apart to see.
Been running since 03 like that always wondering why I never get much battery charging even after driving most of the day.
