Lynnmor wrote:
rjxj wrote:
Lynnmor
But but they did the safety inspection! Our tax dollars at work. State of Michigan requires a 65% score to pass mechanic certification tests.
I wrote about state inspections before and was chastised by the experts here that think they are great. I could write a book about the poor workmanship and downright dangerous things I've encountered.
No, you "WHINED" about PA inspection mechanics and when it was SUGGESTED to FIND OTHER Inspection Mechanics (THERE ARE THOUSANDS UPON THOUSANDS OF INDEPENDENTLY OWNED PA INSPECTION STATIONS ACROSS THE ENTIRE PA STATE), you REFUSED to consider that.
I have NO PROBLEM finding SEVERAL HUNDRED Inspection stations within a 10 mile radius of my home that can and will inspect not only autos but trailers and motorcycles.
YES, there ARE SOME BAD Inspection mechanics and YES, HOWEVER, THERE ARE MANY, MANY MORE GOOD MECHANICS THAN BAD.. Sure, I have had to tryout a dozen or so places over the years before I found one that has consistently good mechanics.
Regardless of that I have ONE MAJOR RULE..
I NEVER, EVER LEAVE my trailers or autos.
I ALWAYS STAND NEARBY AND OBSERVE THE MECHANICS..
Yes, I have noticed a problem and I CORRECT the Mechanic to make sure it is right.
BUT, there have been times when my Inspection mechanic HAS found and pointed out a problem that I missed (I pre-inspect AND REPAIR BEFORE GOING TO A MECHANIC TO AVOID SUPRISES).
You blast PA mechanics as all bad, when in reality they are not ALL bad.PA mechanics MUST also take AND PASS YEARLY TRAINING to keep up to date with the changing regulations and technology.. It is on the INDIVIDUAL MECHANICS DIME to do this.
You also need to realize, PA inspection stations ARE INDEPENDENTLY OWNED AND OPERATED. The STATE (PA) DOES NOT OWN OR OPERATE ANY OF THE THE INSPECTION STATIONS. So making blanket statements about ALL PA Inspection Mechanics like you have is just plain wrong.
Put your money where your mouth is, If YOU think you are way better than all of the Inspection mechanics, perhaps instead of BASHING them you should START YOUR OWN PA INSPECTION STATION!
