Scotccrn's avatar
Scotccrn
F - 150 FYI for 7 pin charging pin
For all you F-150 owners, found out today that my battery charging pin in my 7pin plug was dead. Therefore, it has not been charging or providing power to the trailer for the year that I have owned it. I was about to take it to the dealer when I did an internet search. Apparently, Ford does doesn't like to have that pin hot from the factory. If you look in the baggie that came with the truck, you will find a relay plug in the bag with the brake controller harness. This needs to be installed in order for the battery charging pin to be hot. This may have been covered already in previous posts but I did not see it. The truck or trailer did not inform me of this. The diagram and instructions to install it are in the bag. This saved me $100 or more. You might want to check your pin/fuse panel. You might be going without battery charge too.
