JoeChiOhki
May 20, 2016Explorer II
Finding a Router bit used commonly in RV Construction
There's a type of router bit, its used regularly in RV construction for cutting out Windows and vents in panel/plywood/etc... when RV's are constructed.
Usually a full sheet is installed on a wall, once its glue has set, a router is plunged in to cut out the wood over the window or other opening.
What kind of router bit is that? What is that normally called?
From when I watched them do it years ago, it seemed to have a roller or something of some kind on it to keep it from cutting into the framing when they removed the wood for the openings.
