BarabooBob
Oct 24, 2022Explorer III
Flat springs and now a bent axle
Earlier this year I was doing bearing maintenance on my 2017, 17 ft, single axle TT, bought in 2018. I noticed a small dent in the frame where the spring U-bolts had bottomed out. The springs had lost their shape and were flat. I replaced the springs with American made springs from Northern Tool. Old springs had 1" clearance, new 3 1/2". Much better.
I recently installed new tires on my TT. Upon inspecting the old tires, I found that they were wearing along the inside edge of both tires. I checked the axle to see if it was bent. The axle is bent so it needs to be replaced. I think the axle got bent because of the flat springs bottoming out.
I weigh the TT before most trips because I have free access to a commercial scale 1 mile from my house before I get to the highway and am not overloaded. I checked the axle tag and it say that it is a 3200# on a TT with a 3500# loaded weight.
I will be checking with the dealer that sold me the TT to see if they will replace it. I will let you know what happens.
