Jerseydevil's avatar
Jerseydevil
Flat towing Jeep Wrangler JKU?
Anyone tow behind Class C?
If so, set ups and where to get receiver hitch installed? Bolted or welded? Or both?
Thank you.
    Thank you.
    Research online for a shop. You'll also need a aux brake so likely in the $3K+ range.
    The key takeaway is you “can” spend $3k or you “could” spend “$1300” to tow 100% safely. $1000 of which is for a brake system.
  • bgum wrote:
    Does it have the factory bumper and if so which one plastic or metal?
    Appears factory plastic wrap on outside, steel underneath.
  • sch911 wrote:
    Are you sure your Class C can even tow the JK from a weight standpoint? I'd certainly figure that out before worrying about the equipment.
    Specs are saying it works 6,000 capacity, JKU gross weight 5,400. Just will not be able to load much.
  • Are you sure your Class C can even tow the JK from a weight standpoint? I'd certainly figure that out before worrying about the equipment.
  • I did this for a Minnie Winnie 31G and 2018 Wrangler 2 door JK. It has worked out great for me.
    https://youtu.be/GDid5PpEuF4
  • We tow a 2000 Wrangler TJ (not JKU) but here's our set up and costs, which you could mimic to a degree if it satisfy's your need. All our items ordered from eTrailer -- best prices and free shipping on our orders:
    Tow Bar: Curt Front Bumper Tow Bar (we have steel bumper...you might need base plates and different bar). We opted for solid bar vs. the telescoping bars that cost nearly a grand. C19745 ... $100
    Safety cables: RoadMaster 68" Single Hook, Coiled Safety Cables - 6,000 lbs - RM-643 ... $70
    Aux Brake system for Jeep: Roadmaster InvisiBrake Supplemental Braking System. Item # RM-8700 ... $950
    Charging system line (charges Jeep battery while towing): Roadmaster Battery Charge Line Kit for Towed Vehicles - RM-156-25 ... $30
    Tow lights: We used magnetic lights, to not splice in or factory wiring, since there was no "plug n play" as there most likely is on your JKU. Heavy Duty Magnetic Tow Lights - 20' Wiring Harness with 4-Way Flat Trailer Connector Item # TL21RK ... $38
    Cord between Motorhome and Jeep: Hopkins Nite-Glow Tow Bar Extension Cord w/ Socket - Coiled - 7-Way RV to 6-Way Round - 8' Long
    Item # HM47054 ... $67
    Tax on the above order: $75
    Shipping: $0
    Total cost: $1,260.
    I installed it all myself over the course of 2 weekends. I could do it in 2 days now...a professional in a day.
    Thank you.
  • Does it have the factory bumper and if so which one plastic or metal?
  • Look at Ready Brute Elite for tow bar and integrated braking system. Also, double check your weights - Jeep JKU’s can be heavy especially if you also use them to store more stuff while towing.
