In our shower, hot water flows hot and cold water flows cold. When taking a shower, at normal flow, the temp stays constant. When we push the button to a trickle (oxygenics head) the water temp fluctuates hot/cold/hot/cold. It never happened before until our first trip out a few weeks ago.
The water heater bypass is set to the correct position, both of the outside hose spray connections are capped.
When the kitchen or bathroom sink is running, when the pump strokes, the water gets a a bit hotter just on the stroke then goes back to the set temp.
Does anyone have any ideas?
Thanks
Always looking for the perfect site.
