Follow up to two problems
facory
I presented two problems in previous posts - water heater & city water pressure. Here are the fixes to both.
Water heater not heating on electric: Replaced burned out heating element and replaced anode rod. Works perfectly now.
Low pressure on city water: CW diagnosed the problem and replaced the city water inlet/check valve. A bad check valve was restricting the water flow. Tons of pressure now!
If you encounter either of these issues try these fixes first.
2008 Cruiser RV Fun FinderXtra
Ford F150 Lariat 4x4 SuperCrew 5.4L 6.5' Bed 150" WB 3.73
Schwinn Mountain Bike
2 REPLIES 2
Crdodd
Thanks for the follow up information.
2011Wildcat 312BHX
2008 F350 6.4L PSD SRWCC 4x4 King Ranch
Companion Hitch
Dick_B
If you hang around this Forum for any length of time you would find these solutions being proposed most often for those problems.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
