Ford 6.2 gas vs 7.3 gas highway gas milage
flyte63
Anyone have real world HIGHWAY gas milage figures for a Ford Super Duty with about 3000lbs of truck camper in the bed? I’m specifically wondering about 2017-2021 F250 and F350 trucks with the 6.2 gas and new 7.3 gas engines. Reading online I see claims of similar or maybe only 1mpg less with the new 7.3 gas engine, but what about in the real world? (I know they have their place, but not interested Diesel numbers)
http://flyte63.blogspot.com
56 REPLIES 56
Kayteg1
deltabravo wrote:
...unless the DW is driving.
For decades we've been driving 560 miles route between San Francisco and Las Vegas, often splitting the drive with DW.
We both drove at the same cruising speed, yet DW was making better mpg.
Slower acceleration, less aggressive passing did make noticeable difference in overall mpg.
Than I was coming to the destination 20 minutes faster.
deltabravo
jaycocreek wrote:
These MPG threads are totally dependant on the driver and his habits.
specta
jimh425 wrote:
I don’t think many people run 6.4s stock, but my F450 with 4.30s got better than that stock. I expect most SRWs with 3.73s got much better unless you are talking higher MPH. I didn’t buy mine for MPG.
$8000 is a lot, but not outrageous considering how much new trucks are. Other than DPF issues that no longer happen, mine has had zero issues. I could have bought a new one for 40K more when I bought mine 6 years ago which would have been double the price.
I'm sure there are lots of good ones out there and I'm glad that you have one of them.
I'm sure that this one is actually the oddball, especially with the engine having been replaced twice. this is only the second year that I've used it and its only during the winter months.
I used to tow the snow cat with a 1-ton Chevy and I much prefer towing it with this F-450. Longer wheel base, its heavier and has better brakes and when the going get rough the limited slip or what ever it has in the rear diff helps a lot.
This one has the 4.88 gears but for one reason ort another speed doesn't seem to affect the MPG.
Since it came out of the shop about 8 months ago it runs as good as it ever has. I think someone who knew how to fix it finally got to work on it.
Kenny
1996 Jayco 376FB Eagle Series TT
1997 Jayco 246FB Eagle Series TT
1976 Ford F-250 4wd Mercury Marauder 410 - 4V
Regular cabs. The best looking trucks.
jimh406
specta
jaycocreek wrote:
It was never known for its mpg..
8-12 mpg
6.4pstroker
Most 6.4s get b/w 8-12 mpg stock.Apr 5, 2011
www.powerstrokenation.com › how...
How many mpg should a 6.4 diesel get | Ford Power Stroke Nation
Its a slug no matter how you look at it.
This truck has had the engine replaced twice with new factory 6.4s at the dealer.
I know the lease company has spent over $8000 repairing this one over the last two years in less than 10,000 miles.
I marvel that they have kept it this long.
Kenny
jaycocreek
8-12 mpg
6.4pstroker
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
specta
jaycocreek wrote:
That's not all that bad considering..I had an old 454 that never got better than in the 8's and 6-8 loaded and the weight didn't matter..
It s 390 CI diesel. I would expect better than 8.7 mpg empty on the HWY.
Kenny
Grit_dog
Navigator
Navigator
^Because the old 6.4 Flowerjoke is a turd of a motor. Heck, even Ford who gave the 6.0 about 3 more years than it should have, dumped the 6.4 after only 2 years.
Kayteg1
I disagree.
As Specta says -real value is 1 mpg lower, what considering mostly empty truck is very lousy for diesel.
My Dually averaged real 12 mpg with 6000 lb camper on it.
This is what my cluster said after Alaskan trip. Pretty close to fuelly calculations.
jaycocreek
specta wrote:
This is the mileage display on my work truck, a 2009 F-450 with the 6.4L diesel for power.
If I calculate the mileage on paper it always comes out 1 mpg lower than the display, the same with my Lincoln. I think ford does that intentionally to try and make us feel good. 🙂
362 mile round trip, all freeway and empty.
Lance 9.6
500ah Lifep04
specta
Kenny
CaptJD
I am the owner of a one week old Thor Coleman 19CM with 7.3 engine on it and during the last week I drove it from AR to CA.
Despite being the tiniest possible C class when we hit the strong windy conditions I was making 9mpg average on the flats and 8 to 8,5 on the hills.
Then when we hit the flats again and on a calm evening hours from Blythe to LA we were averaging 10 to 10,5mpg when I set the cruise control at 70mph.
After a while I decided to slow down and set the cruise control to 60mpg and it went up to 11mpg.
Today for the first time on a calm day I was driving back to home on flat roads and decided to cruise at 55mph and it went up to 11.4...
That was my best so far during the 2300 miles in my first week.
To be honest when I first started the engine it scared me. I thought it sounded like a big muscle car! Still think it's a little overkill for a 19' long mini-C class but what do I know?
jimh406
egarant wrote:
I will be picking up a new 2021 Ford F-350 dually 4x4 in less than two weeks.
It will have the 7.3 gas with 4.30 rear end. I will be putting an 2013 Eagle Cap 950 on it.
Congratulations, should be a great truck.
hedge
I is too bad, and always the case, that aftermarket shocks/sway-bars are not available this early in the model year.
I will update the forum as to how this truck performs.
This truck will be replacing a 2013 RAM 3500 4x4 dually.
There are no changes from 2020 to 2021 so should be easy to find aftermarket parts. I wouldn't expect that you'd need any mods for that camper.
I also recently went to a 7.3 gas after owning diesels for ~12 years, mine's a single wheel with the Tremor package. Haven't had the camper on it yet. Don't really expect great gas mileage but not really a factor in my decision to go gas.
2017 F350 Platinum DRW
2013 Adventurer 89RB
billtex
Sweet. I doubt you will need any suspension mods. Payload on that truck is crazy! Of all the mods I have done, sway bar was the least effective. You should be fine.
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
