Ford Edge Question.
Yellowboat_
I've been reading about different tow vehicles. On many of the new Ford's the towing instructions say to disconnect the negative side of the battery. Does this not cause the vehicle's computers and electronics to lose stored memory?
Safe travels. JD
2016 Winnebago Sightseer 33C on a 2016 Ford F53 Chassis
2009 Saturn VUE
Buddy our Bichon Frise
JD & Kathy
7 REPLIES 7
Ovaleye
2016 Edge I just run a charging line Easiest toad to hook up Ive had.
Tim
2003 Safari Sahara
2006 Jeep Liberty
carringb
dodge guy wrote:
If my memory is correct the reason for disconnecting has something to do with the electric power steering. Something with steering input from the wheels instead of the steering wheel. I know on my buddy’s focus he needs to disconnect the battery after hooking up.
Or you could run a charge wire to the car if it’s not necessary to disconnect the battery.
The Focus is much more important to disconnect. It prevent it from going into "Park". Park is in quotes because in really just engages both clutches and locks the two output shafts together, and default low-voltage state is Park, so its safer for the the trans to not have any power at all.
I haven't heard of any issues with the EPS on the Fords, but a charge line is a good idea.
2014 ORV really big trailer
2015 Ford Focus ST
dodge_guy
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Scottiemom
We have a 2014 Ford Flex. The manual does not say we have to disconnect the battery, but after experiencing a dead battery twice, DH installed a knife-blade switch on one battery post and the last thing he does when setting up to tow is throw that switch.
As soon as we open the car up, we pull the hood latch and he reconnects. I read somewhere that if you restart within so many minutes it will remember all the settings. It does. We've never had anything we have had to reset.
Also, if you don't start it quickly, the alarm goes off. LOL
It works great!
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
Traveling with Brendon, my Scottish Terrier
2022 Honda Odyssey
2011 Mazda Miata MX-5
2021 Coach House Platinum III 250DT
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
K_Charles
It remembers everything it needs to remember.
theoldwizard1
Yes. Not that big of an issue for the engine/transmission. It will re-learn within a few miles.
rexlion
I assume you mean "towed" vehicles?
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
