Gjac's avatar
Gjac
Feb 14, 2021
Frame strength of small TT's
I have read on here about frames welds cracking and axles bending. Are these problems basically with longer heavier TT's driven on bad roads or is this prevalent with short TT's, 18-22ft 3500 lbs or less UW also? I can't find any info on frame thickness or material on MFG web sites. I would think that the frame thickness would be the same on a 22 ft vs a 27 ft TT, making the frames stronger on shorter TT's, but that is just a guess. Also I see where Winnebago uses huck bolts instead of welds to attach frame structures together is this process better than welds?
