- transamz9Explorer
mich800 wrote:
transamz9 wrote:
mich800 wrote:
Hannibal wrote:
I remember going from my '01.5 Cummins Ram to my '03 Cummins Ram for the common rail Cummins. The ride with the new cheaper hydroformed chassis was jittery compared to the C-channel chassis of the previous Rams. I've never had the need or desire to drive my F250 loaded to capacity up a set of offset ramps to the point of hanging tires so I still prefer the C-channel chassis. But, Ford is finally following suit on stepping down to the "cheaper" manufactured hydroformed chassis. Good that they're not going with the spindly little aluminum control arm/dried up ball joint assemblies. :B
That "test" was a huge farce. Other than the fact the odds of putting a vehicle designed to tow and haul in that scenario is slim, they intentionally loaded the Ford to have all the weight on the two cross tires where the Ram was balanced on three wheels. But made for good infotainment.
I do believe all three trucks they did in the test were loaded the same. Where do you get your info from?
Watch the video closely. When they pull down on the rear wheel of the Ram it hardly rocks because it is not directly pivoting on the left rear and right front but has weight on all three wheels. When they pull down of the Ford you can see they have it more so all the weight in on those two wheels. It pulled down easy. I am not saying the frame does not flex but this was a staged marketing commercial just like the other manufactures do. So all they accomplished was show what happens to the Ford with two wheels off the ground and what happens to the Ram with one tire off the ground.
No, that is called center of gravity. The Ram is heavier in the front than the Ford. - mich800Explorer
Watch the video closely. When they pull down on the rear wheel of the Ram it hardly rocks because it is not directly pivoting on the left rear and right front but has weight on all three wheels. When they pull down of the Ford you can see they have it more so all the weight in on those two wheels. It pulled down easy. I am not saying the frame does not flex but this was a staged marketing commercial just like the other manufactures do. So all they accomplished was show what happens to the Ford with two wheels off the ground and what happens to the Ram with one tire off the ground. - transamz9Explorer
I do believe all three trucks they did in the test were loaded the same. Where do you get your info from? - mich800Explorer
That "test" was a huge farce. Other than the fact the odds of putting a vehicle designed to tow and haul in that scenario is slim, they intentionally loaded the Ford to have all the weight on the two cross tires where the Ram was balanced on three wheels. But made for good infotainment. - transamz9Explorer
I don't either but I did have my truck in a pretty hard twist last weekend backing the 5th wheel into the spot at the campground. Had to drop my right front wheel off the pavement down in a drainage ditch about 16" deep. - HannibalExplorerI remember going from my '01.5 Cummins Ram to my '03 Cummins Ram for the common rail Cummins. The ride with the new cheaper hydroformed chassis was jittery compared to the C-channel chassis of the previous Rams. I've never had the need or desire to drive my F250 loaded to capacity up a set of offset ramps to the point of hanging tires so I still prefer the C-channel chassis. But, Ford is finally following suit on stepping down to the "cheaper" manufactured hydroformed chassis. Good that they're not going with the spindly little aluminum control arm/dried up ball joint assemblies. :B
- transamz9Explorer
STEVEO496 wrote:
A little frame twist never hurt anyone! I think the whole frame twist debate is way overblown. There are advantages to C channel. For one the whole rail is coated inside and out, whereas tubing may not be. I had a car trailer one time that was made out of box tubing and it rusted from the inside out. Also, there's the bend don't break school of thought. Skyscrapers, bridges and ships are designed to flex because if they were too stiff they would break. A good buddy of mine formally (up until December of last year) worked for Metalsa Frame Div., they build truck frames for Ford and others. He told me that Ford and GM have been having trouble with these new super stiff frames cracking. Their "fix" is to put some extra welds in the area where the cracks are known to occur. I understand the thought behind having a stiff frame, better suspension dynamics, less NVH, better handling. Same reason race cars use ultra stiff chassis, but then again race car chassis' are junk after just a few races. I think this is all just marketing hype, JMHO.
The new frames still flex. They flex where the need to flex. The picture that you posted is of a truck that has near zero suspension travel and it also has no bed or sheet metal that it has to protect like a pick-up. It is also designed to stay on pavement unlike a pick up. A pick-up is designed to go off road also so the suspension is what needs to have the flex not the frame. If you run out of suspension then the frame needs to be strong enough to carry a wheel and not destroy the body work. Skyscrapers, bridges and ship are designed to flex just like the new frames. The are designed to flex in a controlled manner. What do you think would happen if a skyscraper flexed more than its design? It would break body parts like walls and windows.;) - STEVEO496Explorer
A little frame twist never hurt anyone! I think the whole frame twist debate is way overblown. There are advantages to C channel. For one the whole rail is coated inside and out, whereas tubing may not be. I had a car trailer one time that was made out of box tubing and it rusted from the inside out. Also, there's the bend don't break school of thought. Skyscrapers, bridges and ships are designed to flex because if they were too stiff they would break. A good buddy of mine formally (up until December of last year) worked for Metalsa Frame Div., they build truck frames for Ford and others. He told me that Ford and GM have been having trouble with these new super stiff frames cracking. Their "fix" is to put some extra welds in the area where the cracks are known to occur. I understand the thought behind having a stiff frame, better suspension dynamics, less NVH, better handling. Same reason race cars use ultra stiff chassis, but then again race car chassis' are junk after just a few races. I think this is all just marketing hype, JMHO. - HannibalExplorerMakes me want to start looking for a new Superduty. Glad they kept the twin I-Beam IFS. One of the many reasons I prefer a Superduty over the others.
- Cummins12V98Explorer III"Good to see Ford finally catching up"
They have had since 1999 to put a lot of R&D into this totally new truck. It SHOULD put the others to shame!
Question, what are the "truck frames should flex" fans going to say now that Ford has a high strength boxed frame?
If it had a Cummins in it I would give it a serious test drive.
About Travel Trailer Group
44,056 PostsLatest Activity: May 04, 2014
