engineer40
May 28, 2022Explorer
General newb questions - Advice?
Hello all! I just created an account, but I'm excited about my new (used) camper and I plan on becoming a regular on this forum while I learn. It's a 1994 Viking 10ft truck bed popup camper. At this moment, I'm feeling over my head with some things. I'll say thank you in advance for any help you provide. Surprisingly my camper came with all of the original paperwork. I've read through it but still have some very basic questions.
-My camper didn't come with a battery. I found the spot to hook one up. I found where I flip a switch from AC power or battery power. Does the built in inverter automatically charge my battery when I'm plugged into AC power? Does my truck alternator automatically charge my camper battery if the truck is running? Do I need to worry about it overcharging and frying an expensive battery?
-Do most hot water heaters in campers work off LP or electric? The owners manual calls it a "Gas and Electric water heater". But the instructions read like gas "or" electric and not both. I do not see any way to switch from gas or electric. Maybe there is a way and I'm just not seeing it...
-Also in regards to the hot water heater, the owners manual says to make sure there is water in the heater before electric is turned onto the camper or the element will burn out almost immediately. Does that mean if I don't have water in the camper I literally can't plug it into AC power? It's very confusing. I'm nervous I've already burned out the element because I had it plugged into AC power in my garage.
-It has a Dometic fridge. Do most camper fridges have the option to work off of AC power or LP? The manual only talks about LP or temporary battery power (not long term). I think it would be weird if the fridge doesn't work while plugged into AC power because I would want it getting cool while packing to leave home.
I hope all of these questions make sense. Thank you for any help. I'm a single dad. My kids and I are excited to get out and use this, but it's overwhelming even after I read through the Owners Manuals. Thanks!
