time2roll wrote:
3oaks wrote:
"The full power cycling method on most microwaves is easy to notice by the noise change as it goes on and off."
The only time I hear that is when our microwave is set on a "defrost" cycle. And it's not a Panasonic.
Are you using some mid range cooking power? Not going to cycle on full power.
There could be other brands that do the same as the Panasonic Inverter series.
What is it?
Yes, what I meant was power-cycling when the power is set to a mid-range or less. When its set to full power, it just stays on full the whole time.
