HarryBB
Oct 05, 2013Explorer
Genrac Inpact 36 lp - Sleepy Help
I have looked at prior threads - in particular Sleepy's comments back in 2009. Hopefully I'll catch him in a good mood...
1. Generator ran fine last weekend - but battery was weak so I replaced it today.
2. Reversed polarity and blew a couple of fuses but replaced them.
3. Tried to start generator after replacing 7.5 A fuse by "local" start switch on generator... Just getting a click and the gen tries to turn over but doesn't quite get er done.
4. It's in a 2003 1121 - build Oct 2002 - kin to Sleepy 1121. What were the symptoms when you - Sleepy - "wore out your starter"? I wonder if I have the same issue - but only 140 hours on set.
