I can only speak to the Ford prep system but I magine they are similar. There will be 5 cutouts in the bed, 4 in a rectangle and one bigger one in the center. The center one is for a gooseneck ball which are not recommended for fifth wheels. The four outside cutouts allow a fifth wheel hitch that is designed for prep packages to drop right into those holes. The Pullrite in my sig line. It takes 5-10 minutes to install or remove one of those hitches. When removed you have a flat bed.
I understand that the B&W companion hitch installs using the gooseneck adapter.
So you will probably want a new hitch. Some older hitches I believe can be used with an adapter. You really don't want rails in the bed tho.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
