Jun-30-2014 03:19 AM
Mar-17-2015 08:18 AM
Mar-17-2015 08:02 AM
Mar-17-2015 07:52 AM
rhagfo wrote:mpierce wrote:
As in everything, beds have shrunk. To me, a standard bed is 8'. All beds used to be 8'. Then, they came out with short beds.
X2 it use to be that truck manufactures fought as to who could get a 4' X 8' plywood to lay flat in the bed of the truck, with the tailgate up.
Mar-17-2015 06:33 AM
Cummins12V98 wrote:
I had a 77 GMC shorty and loved the truck but hated it for construction.
Mar-17-2015 06:31 AM
blt2ski wrote:
I also have a 26K mdt with a 14' flatbed dump on it, I can carry one heck of a lot more than even a reg 8' bed in a pickumup! 15 cubic yards of material if light enough, or 6 tons of material in total weight.
Then I also have a rack on the bed too. carry 20' pieces of sprinkler pipe etc up there.
At the end of the day, you need what you need. BUT, like noted by some, at one time the std bed was 8', anything shorter was a short be. Anything longer to me is a long(er) bed!
Marty
Mar-16-2015 04:50 PM
Mar-16-2015 04:38 PM
Mar-16-2015 04:34 PM
Mar-16-2015 10:28 AM
x a billion....
Get rid of the short bed, get a std bed, then you are setup.....
BUT, with this in mind, others have said you are ok with your short bed twuck wannabe. So go for it!
Marty
ps, I must be showing me age!?!?!?!?!?!:R:R:R
Mar-16-2015 09:56 AM
car2900 wrote:
Any comments and recommendations would be appreciated.
Mar-16-2015 09:12 AM
labren wrote:labren wrote:ib516 wrote:
I have a short bed on my Ram 2500, and had the same bed length on my previous Ram 3500 Megacab. I tow a 5er and do not have a sliding hitch. My 2014 Ram 2500 has the factory 5th wheel pkg.
Your 5th sits nice and level. I have a 2014 1 ton Ram crewcab and a new cougar that I want to install a hitch into. Not sure of your box size, but mine is 6.2 ft (measured twice) distance from axle to cab as near as I can tell is 37 inches. The dealer wants to sell me a Pullrite Superglide, but I see you do not use a slider. I also have a cougar as you do, a 2015 279RKS 30.2ft with what is called "max turn technology" and the information also says it has a heavy duty extended hitch...(the number on it is 1621 lippert.
I guess after all this, I am also considering the B&W Patriot (non-slider). A little confused at this moment and wondering what steps others with more experience would take to make the decision. I am quite sure the dealer would not want to be putting in multiple hitches while I try and figure which one is best.
Suggestions on this would be very helpful, thank you.
I was not sure how to get a picture of the inbox in here so I added it to the profile, please take a look if you have a minute. Thanks
Mar-16-2015 07:23 AM
Mar-16-2015 06:40 AM
Dayle1 wrote:car2900 wrote:
I currently have a Chevy Silverado 2500 HD with the 6'6" standard bed. I pull a fifth wheel using a B&W Patriot hitch. I have never felt the need to have a slider hitch as I have plenty of clearance to make a tight turn.
I have been looking at the Dodge Ram trucks but have been concerned that the standard bed is 2" shorter than the GM standard beds, I do not want to go to a long bed. The Dodge truck shows 6'4" bed. This 2" would probably mean I would have to go to a sliding hitch if I went with the Dodge. Also the Dodge comes with the hitch pucks that allows you to drop in a hitch as B&W is now making hitches that will adapt to the Dodge and Ford trucks, not so with GM. The 2" difference in bed length will probably mean I will stay with the GM trucks.
The critical distance is not box length, but cab-to-axle distance. And the difference is greater than just 2". GM is 41.6 inches for their 6-1/2 ft bed. Last time I checked (about 6 months ago), Dodge was still at 37+ inches. I can't recall the exact number, and it is hard to find, but anyway the difference is around 4 inches. With a straight front cap difference in max. angle will be about 9 degrees. Ford is about an inch less than GM.
Dodge's shorter cab-to-axle was not compatible with the utility bed I wanted to transfer, Ford and GM were the only options.
Mar-16-2015 06:06 AM
