Gdetrailer
Oct 23, 2020Explorer III
oklatraveler wrote:
Updated question: We'll be going from Branson, MO to Robbers Cave State Park in Wilburton, OK. I'm not interested in points of interest type things, just how the roads are. So if using the Good Sam trip planner is it going to give me the best roads to use for a RV/trailer?
While I do understand your concern about the roads is real to you, it isn't as bad as you are making it.
First and foremost, relax.
Second, I would highly recommend getting yourself some paper maps and DIY the travel plans yourself first. These can be individual State maps or an Atlas which contains maps of all States
Paper maps have road type legends which helps you determine the size and type of road. IF a road you come a across while driving that is not on the map, it IS too small and should be avoided. GPS units often will see those too small roads and attempt to map you on them as short cuts.
GPS is nice to have, but is is just another "tool" to use and is not 100% reliable in all cases so don't take the GPS as gospel but us it as a extra means of assisting with the driving process.
You can also use Mapquest or GoogleMaps to assist in getting a general route but to use that while traveling will require a Internet connection all the time.. Both can give you blow by blow directions that can be printed to hard copy before leaving.. But still, myself, my Atlas is my go to tool I use.
Knowledge is power and blindly following a GPS without some Knowledge can result in less than fun trip if you get routed on a too small of a road that deadends 10 miles in or you find a too low of a bridge only 100 yrs from the end of that road.. Road size is important and GPS units are not designed to show you the size of road by default.
Knowing a route upfront can save you a lot of grief, aggravation and high blood pressure..
A nice "primer" on reading maps can be found HERE
A standard of US maps symbols can be found HERE
44,026 PostsLatest Activity: Feb 24, 2025
