Grand design and towing with a Ford Expidition
Firetraveler
I am looking to purchase a new setup for my wife and I. We are retired looking for a couples trailer. We are interested in getting a Ford Expidition XLT with max tow and fx4 package. We want to use it to pull a Grand design 22 mle. It’s 5200lbs empty with tongue at 500 lbs. 26 ft long. I am looking at going with a Hensley wdh. Looking for any advice from others similar. Thanks in advance.
17 REPLIES 17
carringb
Weight-wise, you'll be generally in good shape. I do like the long wheelbase of the Max, but even the regular version tows well. As mentioned, you could have payload challenges if you need to carry a full passenger load while towing.
As for the hitch, I'd try it without the Hensley first. You probably don't need it. Grand Designs don't seem to generate many towing complaints, and the Expedition is stable as well.
2014 ORV really big trailer
2015 Ford Focus ST
valhalla360
Nomad III
Nomad III
That trailer has a 7000lb GVWR, so the hitch weigh will likely be up around 800-900lb.
Unless you plan to tow with no gear, I would use these numbers for planning purposes. Probably OK but make sure to check both the tow rating and the trucks payload.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
afidel
With the 536 package on the Max that would be a fine pairing for a couple, it might be a little bit more dicy with the non-Max due to the shorter wheelbase. I know the Hensley helps with it, but physics is physics and the bigger footprint of the Max is still going to help fight rotational force from the trailer better.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
