I called Keystone on our 2009 TT for having faded / cracked and peeling graphics. The only ones that were doing this were the words Keystone, none of the swishing ones. Keystone sent me a docuemnt of the different types of graphics available and I picked out the wording that was on mine, took a photo for them and sent it via email. 9 days later - i had a complete set ready to be put on. 1 for the front and rear and 1 each for each side.
When you remove the old ones - be patient and thourough. A hair dryer will removed the old ones with a plastic scraper. You then have to get the remaining glue removed, then clean it over and over again to ensure you have a good surface for the new ones to be applied to. You will also notice that there is some color differnces from where you took the old ones off and the area next to it, use that for your alignment and levelness.
Good luck and yes - this makes a world of difference to your camper.
Happy trails.
