Aug-11-2016 07:17 PM
Aug-13-2016 03:13 PM
LVJJJ wrote:Trackrig wrote:
No it didn't really do any good. I'd take it to an RV shop since you haven't done it before and you're not at home. If you can't get it into one (call a mobil RV tech if you're in an RV park) go to YouTube to watch several videos first.
This is just one of many videos.
Also, while they're in there, have them inspect / adjust the brakes. When was the last time there were done?
Bill
I don't think I agree with this video, he didn't pre-load the bearings by tightening the castle nut then backing it off before inserting the "carter" pin. Also I wouldn't pack the groove in the rear seal with grease as that will seap out in hot weather and possibly get on the brake shoes.
Also have to disagree with coffeegrinder, never have had to replace a single bearing in 27 years of TT RV'ing on any of my several TT's ranging from 1973 to brand new (always replace seals though). I've repacked them all when needed and fortunately they've all been good. Couple of years ago we had an '85 Wilderness with original axles and bearings, repacked them with no problem, who knows how many miles were on them. With good maintenance (repacking at least once a year) they'll last as long as the trailer. Whenever I buy a used trailer, first thing I do is repack the bearings, check all the brakes and adjust if they are in good shape. Should never get a vehicle rolling unless you know you can stop it.
Aug-13-2016 08:09 AM
Aug-13-2016 07:41 AM
Bill
Aug-12-2016 09:47 PM
Aug-12-2016 08:07 PM
Coffee Grinder wrote:
I would recommend replacing the bearing's and seals and not worrying about repacking. Do the same with brake pads
Aug-12-2016 07:35 PM
Aug-12-2016 06:21 PM
Aug-12-2016 06:59 AM
Aug-12-2016 06:31 AM
azdryheat wrote:
Take your trailer in and let a pro handle it. BTW, I believe Camping World charges about $350 for three axles. I forget what two axles is but, for you, it will be worth the hassle of doing it yourself.
Aug-12-2016 06:19 AM
stevemorris wrote:
if its never been don or done recently, do it NOW
its easy, maybe 1/2 hour per wheel, usually takes longer to secure and jackup the tt
you don't need much for tools, jack, lug wrench, pliers and a small hammer and a flat screw driver
Aug-12-2016 05:32 AM
Aug-12-2016 04:33 AM
Aug-12-2016 04:28 AM
Aug-11-2016 10:31 PM
