Grrrr!! What are the big three trying to do????
gitane59
:M Why have all three of the big three made their trucks so bloody high?
My 2010 Ford F350 DRW 4x4 is 55 inches at the back of the bed and our 2014 Heartland Landmark with Mor-Ryde IS sit's perfect level with about 5 inches of clearance between 5ver and TV bed sides.
All three manufacturers now sit between 59 and 60 inches high and won't work with most fifthwheels. Seems like the manufacturers are only catering to redneck's that want jacked up off road bush trucks. I want to trade for a new 4x4 truck but won't accept a jacked up truck for the obvious non-negotiable reason's
1. I don't want to have to climb up higher to get into my truck
2. I don't want to have to have my Mor-ryde IS cutoff and riser's installed to raise my trailer.
3. I don't want a higher step up to get into my trailer if I had my trailer raised by doing step #2
4. I don't want to have to have new step's installed with 5 riser's installed onto my 5ver if I had step's 2 & 3 done.
5. I will not trade both truck and trailer at the same time to accommodate higher trucks. I will trade both for a class A before that happen's.
Hello Big three are you listening???
2014 Landmark Savannah, Mor-Ryde IS with Dexter disc brakes, 17.5 wheels with Sumitomo skins,
2010 Ford F350 Lariat CC LB DRW 6.4L Diesel, Firestone Ride Rite Airbags
85 REPLIES 85
ksss
Travlingman wrote:
gitane59 wrote:
As the OP could I please ask someone with a 2017/2018 Ford Superduty F350 4x4 DRW please tell me how high the bed rail is at the tailgate with 3200lbs sitting directly over the rear axle?
I keep reading and hear about of this suspension squat underload due to progressive rate springs installed in this trucks to soften the unloaded ride.
My beds rails sit at 55 inches off the ground loaded or unload thanks to my air bags and my 5ver overhang is about 61 inches off the ground with the trailer level. And no it's not 15 year old.
I can't imagine the new truck squatting 5 inches under a load of 3200 lb's but anything's possible I guess.
I just know that I'm not raising a perfectly towing trailer to fit a truck designed for off road busk escursion's. Speaking of that who in their right mind takes a dually offroad onto bush trail's. Dually are made for hauling heavy loads not trail driving
As I posted earlier, I have the exact same trailer as you and a 2017 F-350 dually. I have around 8" clearance, camper runs level when hooked up and my rig is stock. Unless you changed from factory height when you did the IS, yours should run the same as mine.
I have 8-9" with my Chevy 2018 3500 after some adjustment. It is just slight nose high. 6" of clearance might be enough if you never get off asphalt. I found out first hand it is not adequate on a toyhauler that leaves pavement for forest service roads.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
transamz9
Groover wrote:
After seeing a review of the new Ranger showing how tall it is and looking at some Colorado's I went and bought a 2008 Ranger for use around the farm and am about to take it to get some potting soil for my wife. I love my 2016 Ford truck but dearly wish that it came with air suspension that I could make kneel for loading.
Like my 2005 Ram? With air dropped the tailgate is 30" from the ground.:B
Click For Full-Size Image.
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
Groover
fj12ryder
All a lovely argument I'm sure, totally beside the point, but a lovely argument..for something.
But of course this whole thread was started with complaints about height, not towing ability, not hauling ability, but height. Trailers are getting very tall, with lots of them approaching 14'. If you have to lift a trailer that's already 13'9" you don't have much room to work with. And taller is not necessarily better, both in trucks and trailers.
Howard and Peggy
"Don't Panic"
Grit_dog
Navigator
Navigator
Ok so I get it. New trucks are taller old ones were short, horses used to pull the original campers around (covered wagons). Things change.....
But is anyone SERIOUSLY complaining because today’s cars and trucks are heavier than in the past??
That is like creating a solution for a problem that doesn’t exist!
So a 450hp muscle car is 1000lbs lighter than a new muscle car? Compare to my fave 70 LS6 Chevelle SS. I guarantee my new SRT stops twice as fast, double the perf on the skid pad and absolutely eat it’s lunch in the 1/4 mile stock for stock. All while getting 2x the gas mileage twice the longevity of components and it’s like sitting in a spa with a 400W sound system!
Trucks haven’t gotten much better though..... lol. I’ve run the **** out of he best the 70s, 80s and 90s had to offer and even my old 07 will absolutely destroy the best big block truck made in towing, handling, mileage, comfort and power. And it’s behind the curve now compared to the new ones in every department except raw power but I had to mod to get the power I got. Oh wait, the reg cab bench seats were soooo much better than the worst seats everyone complains about now though.....
Y’all keep wishing for the stupid old trucks to come back and anyone who’s serious about it, I’ll find fine examples of yesteryears iron and you can trade me for your horribly tall and heavy new Powerstroke or Duramax!
Cheers!
Travlingman
2017 F-350 King Ranch DRW
2014 Landmark Savannah(sold)
2022 DRV Mobile Suite 40KSSB4
JAC1982
We aren't going anywhere for 2 weeks but if I remember, I will measure ours when we hook it up again. I don't know what our load is but our trailers are a similar size/dry weight so I'd guess the load is similar.
2020 Keystone Montana High Country 294RL
2017 Ford F350 DRW King Ranch
2021 Ford F350 SRW Lariat Tremor
hone_eagle
The biggest contributor to weight gain is the crush/crumple zones , side impact , and other 'stuff'(steel)that air bags need to push against , to get that 5 star safety rating, remember any thread that if a manufacturer only got 4 stars in some test?
Its a big deal.
2005 Volvo 670 singled freedomline 12 speed
Newmar 34rsks 2008
Hensley trailersaver TSLB2H
directlink brake controller
-when overkill is cheaper-
fj12ryder
So you have 6" of clearance. I don't see the problem.
From reading his post that 6" of clearance is with his present truck. He's asking: "As the OP could I please ask someone with a 2017/2018 Ford Superduty F350 4x4 DRW please tell me how high the bed rail is at the tailgate with 3200lbs sitting directly over the rear axle?"
Howard and Peggy
"Don't Panic"
ShinerBock
Turtle n Peeps wrote:
Cars have been under EPA rules for many, many years. Even though they are under EPA rules they have been getting fatter and fatter and fatter over the years.
Lets pick one and see what it has done over the years.
1970 Challenger (a car I own)= almost 3,500 lbs. 2018 Challenger= almost 4,500 lbs!!!!!
Almost a 25% increase in weight!! Even the Dodge Demon (Dodges factory drag car) weights 4,500 LBS! Look at a Ford Thunderbolt (Fords factory drag car) weighed 1,300 lbs less!!
And yes I know "some" of this stuff is mandated by the government. Things like airbags and cats and things like that are mandated but still add a lot of weight to these cars. Things like 132 cameras and butt heated and cooled seats, 45" TV screens are not.
I say the manufactures will save a few 100 lbs and that's about it. Much like when Ford went with an aluminum body. A lot of GM trucks still weigh less or the same as the Ford trucks.
Trucks have been getting bigger and heaver for almost 100 years. I don't see the trend changing anytime soon.
This also is due to EPA regulations. These regulations and technology have changed over time which have caused vehicles to change over time.
The regulations of the 70's forced cars of the 80's to decrease in size and in engine displacement. Then manufacturers started using lighter weight materials in vehicles and engine technology allowed larger engine to not only meet emissions but also fuel economy standards. There was also a long period in the 90's and 00's of no increase of CAFE numbers while the emissions requirements increased as seen in the timeline below. This was when most vehicles started to grow because engine technology and lighter weight materials outpaced the regulations.
Then stricter standards came in the 10's that added a vehicles "footprint" to come into play on its fuel economy rating. A manufacture had to combine the average footprint of the vehicles they sell in order to see what fuel economy standards they need to meet which changes year of year depending on what vehicles they sold the most of the prior year. So any manufacture, such as Ford, who sells more trucks with a larger footprint has a lower CAFE number to achieve than say Nissan who sells more smaller vehicles.
Notice the footprint on the bottom determines what CAFE number you need to reach.
This is what killed small vehicles like the Ford Ranger in 2011 since it had the footprint of a compact car, but got much worse fuel economy. This would have forced Ford to reach a much higher CAFE number (that started in 2012) since they sold so many of these small footprint trucks. So now it is more beneficial for a manufacturer who makes a lot of big vehicles, like Ford, to only sell big vehicles because it lowers their CAFE requirement. This is probably the reason why Ford is dropping most small cars from their line up.
During this whole time, Class 2B and up vehicles have been exempt from these fuel economy standards and only had to meet emissions so they grew in size over the years. Starting in 2021 that will change and you will start to see fuel economy rating on their window stickers.
2014 Ram 2500 6.7L CTD
2016 BMW 2.0L diesel (work and back car)
2023 Jeep Wrangler Rubicon 3.0L Ecodiesel
Highland Ridge Silverstar 378RBS
Turtle_n_Peeps
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
ShinerBock
ShinerBock wrote:
Why is the bed so tall in the new Fords? The same reason why the beds got taller on the GM and Ram trucks when they went with fully boxed frames in the rear. The benefit of C channel frames of the older body styles where lower bed heights.
I know what you are saying SHinerBock but if they are tying to save weight the manufactures are doing a piss poor job. Look at the weight of a lets say 06 Duramax (my truck)and the weight of a 18 Duramax.
I just got home from working on a 66 Burb. I thing it weights 4,600 LBS. What does a newer 3/4 Burb weigh?
The new vehicles are PIGS and are getting more piggy every year!
They only recently started to try and save weight because the new EPA phase 2 was only finalized a few short years(2016) ago and will be gradually implemented from 2021-2027 for Class 2B and up vehicles. Up till now, these trucks were exempt allowing the manufacturers to make them bigger and bigger so they can have the hardware to match these exorbitant towing numbers they are rated at. With the new standards finalized, I have no doubts you will see these HD truck manufacturers do more and more to increase fuel economy. Or at least enough to get as high as they can on the test which hardly reflects the real world.
Final Rule for Greenhouse Gas Emissions and Fuel Efficiency Standards for Medium- and Heavy-Duty Eng...
transamz9
gitane59
Turtle_n_Peeps
outside the fire"
