MT_Camper's avatar
MT_Camper
GVWR
I Have a 2017 F250 GVWR 10,000 lbs, rear GAWR 6340, front GAWR 4400, E rated tires at 3640 lbs. I have added 8600 lb Timbrens, lower stable loads and a Hellwig bigwig sway bar. I weighed my truck full of gas, two passengers, camper full of water and everything else we thought we needed to bring. The Cat Scale weighed in at:
Front axle 4060
Rear axle 6340
Gross weight 10400
The scale shows I am 400 Lbs over my GVWR listed on my truck.
The truck handles the camper very well.
My question is will this present any problems and what can I do to help?
Any helpful suggestions will be appreciated.
Thanks!
Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" at the top?
    Forum Posting Help and Support is reserved for "how-to" question related to posting in the forums, signature and photo testing, or reporting member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, go to the RV Forum which corresponds to the subject of your topic, and click the Post New Topic link. Thank-you!
Moved from FORUM POSTING HELP AND SUPPORT
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 18, 2025
