- beg4mercyExplorerThis is what I have and I always get compliments on it. Just used it over the weekend to grill steaks, vegetables, hotdogs and hamburgers. Worked like a charm!
http://www.trekwood.com/products/181475/Grill-Gas-Flame-King-Black-w-Mounting-Bracket-Case
Whoops. Just read further that you're looking for a burner stove.....my fault. - BlacklaneExplorerJust about any propane camping stove can be used, but it will probably need a simple modification.
RV propane systems are low-pressure. Right after the tank(s) is a regulator that lowers the pressure before it's distributed to the RV, including the outdoor quick-connects.
Most stoves use high-pressure, but have a regulator that normally attaches to the propane bottle. Downstream from that, it's low-pressure. To use a typical stove on low-pressure, all you have to do is remove the regulator and attach the supply hose there.
Any good propane supplier will have the fittings needed to do that. (There are a few off-shore suppliers that use metric fittings, though. That will make it difficult to convert to US fittings.)
There are a few postings in the "Do It Yourself Mods" section of this forum that cover this. - Mark_and_LindaExplorer
Mark and Linda wrote:
I have a grill that came with my PUP that I traded. I looked at the label and it came from outdoors unlimited.
Have you looked at Surburban....we had a small Palomino PUP that we could use the inside stove outside also if we wanted. It had a quick disconnect on it.
http://ouioutdoors.com/rv-accessories/
We bought a new Palomino PUP back in 2009 and it came with it, plus the one inside. Hope this helps.
This is what we had:
http://www.amazon.com/Mounted-Motorhome-Barbeque-Installation-Included/dp/B0070OC80E/ref=sr_1_9?ie=UTF8&qid=1423493778&sr=8-9&keywords=outside+rv+propane+stove - Mark_and_LindaExplorerHave you looked at Surburban....we had a small Palomino PUP that we could use the inside stove outside also if we wanted. It had a quick disconnect on it.
- seaeagle2ExplorerI just remembered, I was trying to use a specific stove that uses the small bottles, Camp Chef "Ranger" series stoves will work, they sell an RV quick connect hose for that model stove, I was trying to use it with a "mountain" series which won't work.
- seaeagle2Explorerpart of the issue is there's low pressure and high pressure stuff. If you have a stove that uses a small bottle, it has a different fitting because the pressure is different. I have a two burner stove that uses the small bottles and I was trying to figure out how to get a hose so I could use the quick connect fitting on the side and I gave up... They make the fittings different so you can't hook up the wrong pressure.
- LynnandCarolExplorerActually looking for a 2-Burner Stove.
- 2006_SMOKEYExplorerI went a step further and bought the hybrid (both gas and electric). It is a bit pricy but I love versatility. I am super happy with my Olympian Hybrid. Got it at CW.
- icanonExplorerIs this what you're looking for ?
About Travel Trailer Group
44,027 PostsLatest Activity: Mar 05, 2025
