Bubtoofat
Jun 10, 2020Explorer
Happijac Help
I have motorized Happijac 4150 jacks on my camper. For the most part they have been trouble free. This spring when I used them for the first time the two front jacks would NOT cooperate. The lacks ...
ejfranz wrote:
Be careful, one of my 4500 failed. The nut the worm screw runs through rusted out.
When you pulled them apart was there rust on the worm screw? If so the main nut is rusting and could be binding.
Z-Peller wrote:
When you pulled the jack apart and greased etc, did you pull off the cinch spring and check the roller bearing in there?... use emery cloth to clean up the thrust block sufaces and washer the bearing runs on?...I have also had to emery cloth rust from the hand crank barrel and bore when it is apart..
