woodhog
Jul 13, 2013Explorer
Happijac Motor Cover
I have one jack not operating, I checked the controller board, found a blow fuse to the failed jack motor..
Jack moves good mechanically with crank..
I removed the jack and motor assembly, with its little transmission attached, took the motor out of the transmission mount assembly after removing the gears..
The transmission gears are all in good shape.
I cannot move the motor shaft with my fingers and suspect it is maybe bearing trouble in the motor...
Does anyone know how to remove the actual round cover on the motor itself.
[img]
[/img]
It appears to be just jammed down over the motor...
[img]
