Help AC and heater not working!
Joygoetz
Hello, I have a 2016 Shasta forest river 30 foot travel trailer. Ac and heater were working fine and now both don’t work. I have checked all circuit breakers and all seem fine. I have checked all fuses with a tester all were good but I changed the ac fuse anyway. The battery is working because when I unplug the rv from the 30 amp plug in the lights and all work. Everything thing else are wirking. Lights, frig, micro, radio, bump out. I changed the Tstat.
I checked my red Tstat wire with a 12vd bulb and it did not light up. I think I don’t have any juice to my red wire?
Any suggestions would be greatly appreciated.
Joy
NOTE: Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions on how to post in the forums, signature and photo testing, reporting website or member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, create future threads in the RV FORUM which corresponds to the subject of your topic. Thank-you!"
15 REPLIES 15
2oldman
mike-s wrote:
If they can't be bothered to do either, they don't deserve the luxury of asking for help, and any answers would be beyond their comprehension anyway.
He can't be bothered to answer my question either.
mike-s wrote:
Not only do people who post to "Forum Posting Help and Support" not read the title, they don't read the "Read this before posting" sticky post.
That link should be changed to display all forums, not take brand-new users to the least-used forum in this place.
I think Forum Technical Support was a less confusing title than what it was changed to, and will likely never be changed again. This kind of reminds me of working for the government, where they simply refuse to change something that's not working properly or is confusing, but somebody in charge thinks it's not worth bothering with.
Joygoetz
Thank you everyone . I didn’t mean to cause any problems with my posts. I was just eager to get help and fix this ac and heater. I will not post again until I read all the rules.
Thank you again everyone! I am out of town for a week but will ask for help again when I return, if that is ok.
Have a wonderful day!
Joy
PaulJ2
Most likely source of the 12 volt thermostat power is from the furnace itself.You might check there for blown fuse or tripped breaker.
No power from there to the thermostat and no AC either.
time2roll
mike-s wrote:
2oldman wrote:
Definitely sounds like a tstat problem.
This forum should be labeled "Post everything here and we'll move it."
It should be "post here and it will be quickly deleted without comment." Not only do people who post to "Forum Posting Help and Support" not read the title, they don't read the "Read this before posting" sticky post.
If it is that big a deal then new members should be restricted to not see the "Forum Posting Help Forum" for the first few posts.
There are other new member restrictions... just add one more.
mike-s
time2roll
Battery will supply the 12+ volts needed to run the thermostat and furnace fan. This is how people camp off-grid every day.
You have an open circuit between the battery and the fuse panel or between the fuse panel and the items that do not work. You will need to systematically look for 12 volts along the entire path to find the open circuit. Generally it will be at a junction, fuse, switch or breaker. Generally not mid wire. When you find 12v on one side and zero on the other of one of these items you need to clean, tighten, adjust, repair, or replace that item. If this seems daunting it might be best to call a mobile repair person or haul it into a shop.
Since your lights work I assume 12v power is getting to the 12v fuse panel. Pull each fuse and test with the meter.
Converter is easy. 120vac in, 13.6vdc out. Only trick would be getting to the wires. Need to disconnect from the battery to make sure you are not reading battery voltage. Divide and conquer.
Joygoetz
Hello, I checked the battery and it is fully charged. With the battery only my lights work, frig, micr, radio pretty much everything except ac and heater.
If my converter is bad how do I check it?
Joy
time2roll
Check voltage on the battery terminals. The check voltage off the converter output in the 12v distribution bus. I assume the converter is failed and battery is dead. Do the lights work?
If voltage is low put a portable charger (5+ amps) direct on the battery asap.
1492
Moderator
Moderator
2oldman
Joygoetz wrote:
.. I have no powers going to the Tstat.
Does the tstat have batteries, or does it use coach power?
Joygoetz
Hello and thank you for all your advice . A few questions: 1. How can I trace the power from my Tstat to the power source? 2. I can’t see any wires or fuses by my battery? 3. I tested our battery and it had a full charge? 4. Interesting info on the delay in the Tstat but I have no powers going to the Tstat. I also am plugged into a 30 amp line and have the battery on???
Any suggestions ?
Joy
rockhillmanor
On many RV's the thermostats on fridge, furnace/ac are run off 12v.
Yes you tested the 12v with the light coming on but the thermostats need a full charged 12v to operate, light do not they will come on with a low battery until the battery dies.
Check the output of your converter AND check your coach battery at the battery. Any type of 'low' voltage will cause the thermostats not to work.
The heat and ac will come on but when it hits the temp set and turns off it will not come back on if low voltage is present.
Also, if you have been "flicking the on off switch on the thermostat" trying to get it to work you've put it in between the delay mode and it will appear it is not working.
1.Step away from the thermostat,
2.quit flicking the on off switch,
3.put it on the ac mode,
4.set the temp for a temp where you know it 'will' come on depending on temps where you are located right now.
5. and WAIT...for the delay to cycle.
My delay is pretty long or so it seems like it. And to this day many times when I turn it on, I still get that panic feeling that my ac is broke when it doesn't come on immediately.
2oldman
JOHN_LAURA
Same thing happened to me, but with the slide out. Checked everything and could not figure it out. Finally found the breakers/fuse things on the frame rail right past the battery. has a wire that goes on top and one on bottom. I had 3 of them. Everyone of them was loose. After I tighten them all up the slide out worked fine.
john
2018 RAM 2500 4X4 CTD
2017 TOYOTA CAMRY
2019 GRAND DESIGN REFLECTION 311BHS
THE WIFE AND I
SON 21 DAUGHTER 15
WONDER DOG LUCY
