My tub cracked and I'd like to replace (not repair) and reinforce it so it doesn't happen again. I can probably get it from Northwood but I'd like to have options. I need help identifying the make...
Looking up from my FW basement, I can see a bit of the underside of shower tub. It is completely reinforced with hard foam board between pan and floor. Just the drain itself, with pluming below is showing. It is the most solid to stand on, of any that I've had.
If your tub is not reinforced well, it would be a good time to do so, before reinstall.
