HaulinBass02's avatar
HaulinBass02
Help setting hitch head angle
So we went to pickup out new/used Trail-lite 30BH today. I already thought I might need a longer drop hitch shank and it was confirmed today. Need to get about a 7" drop, basically I need to go down about 2 more holes on the shank that I don't have....
Regardless, we were still able to get hitched up and when I went to put the WD bars on I could barely get them in the 2nd link. The bars were also at a downward angle quite a bit.
The coupler is a bottom mount, meaning it is inverted and welded to the bottom of the frame rather than the top. So this already creates a weird offset for the WD system anyway. Do I tilt the hitch head forward towards the suburban to help the bars align more parallel to the frame and get more links on the bracket? What would be the best way to do this?
