minihub67's avatar
minihub67
Help with towing set-up
I have a 2011 F-150 with 3.55 gears 3.5 liter turbo 9,600 lb tow capacity.
I am looking at the following situation considering new travel trailer and could use some opinions if I should be ok.
I just weighed my truck full of gas with me in it... I'm at 5,830lb my GVWR on the truck is 7,100lb. If I add the wife dog and son I'm at 6,145lb leaving 955lb for tongue weight.
Trailer below: unloaded vehicle weight shipped is 5,900lb It has the kitchen over the rear axle and I suspect I would be around 6,600lb loaded.. I would think adding batteries and filling tanks with equalizer hitch, would add lets say 120lb. Now dry hitch wt (I know not loaded) 630+120=750lb.. Even assuming the trailer were at 6,800lb loaded, I would say using the example of 12% that's used to assume tongue weight I would be at 816lb o the tongue. I should have 955lb to play with so I would think I would be ok..
Any thoughts on my assumptions?
Thanks,
Jayco Whitehawk 27DSRL
Unloaded Vehicle Weight (lbs)
5,355 (should be 5,900 shipped)
Dry Hitch Weight (lbs)
630
Gross Vehicle Weight Rating (lbs)
7,500
Cargo Carrying Capacity (lbs)
2,145
Measurements
Exterior Length
30' 11"
Exterior Width
96"
Exterior Height with A/C
129"
Interior Height
81"
Queen Bed
60 x 74
J-Steel Convertible Sofa
42 x 60
Hide-A-Bed Sofa (Optional)
54 x 74
Wheel Base
241"
Tank Capacities
Fresh Water Capacity (gals) includes water heater
46.2
Gray Waste Water Capacity (gals)
30.5
Black Waste Water Capacity (gals)
30.5
Other
Sleeping Capacity
4-6
