joe&julie81 wrote:
I'm thinking about getting a 2 or 3k amp power inverter to hook to my truck batteries and running a heavy ext cord to the shore power of the camper, in lieu of a generator. This would replenish my camper batteries after sitting awhile running fans, furnace, lights, etc. I could crank the truck for 20 or 30 min occasionally with a high put alternator to replenish the truck batteries. Anything wrong with this thinking?
A couple things to consider; a) Powering a 2-3K
watt inverter from your truck batteries is wishful thinking unless you've done some serious upgrading to your batteries. b) There are a lot of losses going from 12Vdc to 115Vac, then back to 12Vdc again... and then unless you have a high current converter or charger in your camper you won't be able to do much charging in 20-30 minutes. c) You stand a very good chance of discharging the truck batteries to the point at which you can't start the truck.
You may be better served by a small generator or a solar charging system.
HMS Beagle wrote:
You also have a large battery bank of AGMs, which will absorb much more charge, for longer, than the typical one or two flooded cells, and added the cabling to feed them. If you are going to do this it should be part of a complete system....
This is a good point HMS. Although the OP's question was about alternator swapping, when considering
any electrical system upgrade it is important to look at the system holistically. Otherwise, any one weak-link will severely limit charge current.
theoldwizard1 wrote:
Did you have to do anything to your charging system to get it to deliver that kind of voltage ?
3rd gen' Ram trucks regulate the alternator output to 14.6V (temperature dependent), so I did not need to make any changes. There are aftermarket regulators available, but since most alternators are PCM/ECM regulated, changing the voltage not as simple as it used to be.
Cheers
-Mark
