labren's avatar
labren
Hitch removal acceptable procedure?
I have seen two 5th wheels so far, that have had the hitch suspended off the pin and the truck was out from underneath, being used for whatever the owner wants to do with it. When he decides he wants the hitch back in the truck, he backs under the pin and lowers the 5th and hooks the hitch back up, saving his back from trying to lift the hitch. Some of you may have seen this and have an opinion on it, which I for one would like to hear. Is this hard on the 5th wheel or an acceptable procedure? As always I hope this generates a useful informative discussion, thank you!
  • I have a Pulrite slider and take my hitch apart. Slide the hitch on carpet on top of a cart I built, that is the same height of the tailgate. and roll every thing in to the garage. Don't like the idea of all that weight in front of the trailer and I can see myself knocking my head on it every time I access the front storage door.:S
  • My hitch just came out of the truck, second time since 2008. The first time it came out with a fork lift, the second was attached to the trailer. I didn't want to leave it dangling so I placed it in my utility trailer. I took it out so I could take advantage of a FREE rhinoliner.
  • I used the trailer to lift out the hitch as described and it worked ok but very hard to line up feet to reinstall hitch. I had to unhook hitch once it was sitting close on rails and then pull truck forward to get in bed to actually properly set feet and pin in rail. I have a Harbor Freight electric winch mounted in the rafters of garage and that works much easier. Pull pins, attach winch, lift out of bed, pull truck out from under, lower hitch to dolly, move hitch and dolly to corner of garage out of the way until needed next time..
    Randu
  • How can one worry about the weight of the hitch damaging the king pin? The static load of the hitch is less than two hundred pounds. Compare that to the thousands of pounds of dynamic load the pin has take to pull the trailer. We've all seen pictures on semis turned over on the road where the tractor and trailer did not separate. Our fifth wheel pins are identical.
  • It can/has been done.
    Hitches are heavy....5vrs landing gear/king pin can easily lift them out of truck
    Some concerns (not mine)
    Jaws getting damaged by weight of hitch hanging from them
    King Pin getting damaged by weight of hitch hanging from it
    Handle getting moved, releasing hitch and it falling off king pin
    When I was strapping young man I would do it myself.
    Then I got a bit older......still strong but I work smarter now and use mechanical advantages when possible.
    I have NO concerns using king pin to lift hitch out/in truck and it can hang on king pin. If pin or jaws prone to damage/failure....then wouldn't trust them when towing
  • agesilaus wrote:
    We did that one year but it made me nervous since we have a semi-psychotic kid living down the road. My hitch easily breaks into two parts, the head section and the base. All I have to do is pull two cotter pins. Then I can just lift the two parts out one at a time. They are both individually light enough to manage. Much safer in my case. Takes me about 10 mins max to take our Pullrite out or to install it.
    * Thank you, is your truck box a 6.5 or 8.0 please?
  • We did that one year but it made me nervous since we have a semi-psychotic kid living down the road. My hitch easily breaks into two parts, the head section and the base. All I have to do is pull two cotter pins. Then I can just lift the two parts out one at a time. They are both individually light enough to manage. Much safer in my case. Takes me about 10 mins max to take our Pullrite out or to install it.
