ashnic
Sep 15, 2014Explorer
Hitch setup recomendation
We are looking at moving to a slightly larger TT. Weight being newer is about the same..but it is about 7' longer. I get a little bit of sway now so I assume it might be a bit more with the longer trailer. I am currently using what came with our current trailer when we purchased it..it's a reese setup with weight dist. bars and a antisway friction device. Several years ago we had a Equalizer setup that seem to do a good job helping control sway but again that's been several years ago. Is there newer setups that are better now or is the Equalizer setup still pretty good? I will be pulling about 8k with our 2012 2500HD in case you are curious..Thanks in advance!
