Tequila
Jun 07, 2016Explorer
hook to shore power and plug a tester into the micro outlet. I think you will find it is wired worng. When you power with the honda you do not have a neutral (normal) and a miswired outlet could be causing your symptoms. My honda will run my a/c if I turn off all sources of power drain, switch the fridge & hot water to gas and shut the off the convertor from charging the battery.
