- TequilaExplorerMy honda 2000 will run my 13.5 A/C, but I have to turn off the occonvertor so its not trying to charge the battery at the same time and force the fridge to gas.
- blksmithExplorerMy Honda will run the A/c If you start it on a warm setting and once its running turn the a/c to coldest setting. If the a/c cycles it won't re start it. better than nothing either reaql hot or real cold..
TJ - sushidogExplorer
Robin25113 wrote:
I wonder why the RV manufacturers don't consider split A/C systems? I really like the EER ratings.
Exactly. You could run 2 of these 12,000 Btu 21.43 EER mini-split ACs from one EU2000 Honda. http://www.geinnovations.net/HSAC_Productline.html
The problem is cost. Two of these mini-split heat pumps will run $4,000, not counting the cost of two $364 converter chargers to run these native 48v DC devices off of 120v AC power. http://www.ebay.com/itm/DLS-54-13-IOTA-CONVERTER-CHARGER-13-AMP-108-132-VAC-NEW-/321783735939?vxp=mtr&hash=item4aebce2683
However looked at another way, you could run one of these 12,000 BTU ACs all night on 8 golf cart batteries recharged by solar, drawing at most only 560 watts (11.5 amps of 48v DC power.)
In fact my next travel trailer will be set-up for full-time off-grid boondocking, using one of these super high-efficiency mini-split heat pumps and about 2,000 watts of solar for totally self-sufficient power production. I'll start with 10, GC-2 (golf cart) batteries for my storage needs with both a 12v electrical system (for slides, lights, fridge board, heater blower, etc.), and a 48v electrical system for the 48v DC heat pump and inverter to power all my 120v AC devices. The single EU2000 Honda I plan on using for backup battery charging in case of inclement weather, when solar is ineffective will be more than sufficient for my recharging needs through a 2000w 48v AIMS pure sine inverter charger like this. http://www.amazon.com/Power-PICOGLF20W48V120V-2000W-Inverter-Charger/dp/B00IRKZPE6/ref=sr_1_8?ie=UTF8&qid=1425476298&sr=8-8&keywords=48v+inverter
Chip - pianotunaNomad IIIYes which is why I use a hybrid inverter fed by a Yamaha 2800 inverter genny.
Luv2Q wrote:
DB, if the Eco throttles are on, do you get a lag (short brown-out) when the compressor cycles on? That's what my dual setup does, & I'm wondering if it can damage the ac. - Luv2QExplorer
deltabravo wrote:
Late summer I bought a second EU2000i, the companion model.
All is well now. I will take both gens if I want to run the A/C.
DB, if the Eco throttles are on, do you get a lag (short brown-out) when the compressor cycles on? That's what my dual setup does, & I'm wondering if it can damage the ac. - I agree with others that say "most likely not"
I bought a EU2000i in 2001. In 2003 I bought a Desert Fox toy hauler with 13.5K BTU A/C. running it on the gen was hit and miss. Mostly a "miss"
In 2010 I sold the toy hauler and got a truck camper, also with a 13.5k BTU A/C. Same story, second verse. It was mostly a MISS with running the A/C. Late summer I bought a second EU2000i, the companion model.
for Fall/Spring camping, I will only take one gen. - Luv2QExplorerThis may properly need to be a thread of its own but, since it's on the topic of Honda EU2000s to run ac, I'm hoping this will be ok.
I just got the EU2000 + Companion to run a 13,500 Dometic. With Eco throttles off (running at higher RPM), no issues. With Eco on, however, the EMS throws a low voltage error because there's a short lag before the gennies spool up. I can bypass the EMS which keeps the ac going despite a momentary 101/102 voltage reading (as shown by a Kil-a-Wat).
Question: Will a short duration brown-out (maybe a second or less) cause any damage to the ac?
Thanks in advance to anyone who cares to weigh in.
John - AtleeExplorer III just carry two EU2000i generators, one being the Companion. But I do not camp in campgrounds that limit generator hours, nor do I camp in commercial campgrounds.
In the fall I got to football games. We tailgate (camp) in an open field. In September, the temperature often requires the AC. On most weekends in Oct, and all weekends in Nov, we don't need AC. For those weekends, I'll still hook up both generators, but will only run one at a time.
In November, I need enough electricity to run an electric heater. - HuntindogExplorerThe problem with all of these "tricks" is that they may work fine, when having the AC is just a "nice to have" thing.... But will likely not work when it becomes a necessity.
In AZ, I may NEED the AC to work when its 115 or hotter out. Having a generator that may or may not do the job is not something I will tolerate.
YMMV - SoundGuyExplorer
colliehauler wrote:
Like I said Sound guy to each his own. In other words they can do as they wish. To me it does not make sense to go to all that trouble.:R
So in other words we agree. ;)
About Travel Trailer Group
44,027 PostsLatest Activity: Apr 19, 2019
